MF Xtra
September 14, 2016
Wednesday, September 14, 2016
MetalForming Xtra Newsletter
September 14, 2016
Subscribe | Become a Sponsor |
Read All About It
Skills Gap Not to Blame for a Lack of Hiring
According to a recent report from the Bureau of Labor Statistics, manufacturers posted 379,000 job openings last July, up more than 280 percent since the recession ended more than seven years ago. However, hiring is up just 36 percent during that time, and has been flat over the past year as manufacturing jobs go unfilled.
While the skills gap often gets blamed for this, this article concludes that "it's not clear that companies are really trying hard to fill many of these jobs at all."
Citing survey data, the report notes that 62 percent of manufacturing production workers have no education past high school, and 80 percent have neither an associate's nor a bachelor's degree, and suggests that manufacturers aren't replacing less-educated older workers with more-educated young ones. Rather than degrees or licenses, what employers say they are struggling to find are workers with industry-specific skills, such as how to program the machines that do much of the physical work in modern factories.
Here's the article.
Sponsors
Picking Up What
Vacuum Cups Cannot
Transporter®LP magnetic end-of-arm tooling is designed to transfer metal blanks, stampings and parts in automated and robotic applications. Engineered with powerful Rare Earth magnets, they will hold parts during power loss, minimize part shifting, provide more options for picking up perforated or odd parts, and reduce shop air costs significantly compared to vacuum cups. www.magnetics.com
Consistent Stock Lubrication Systems
Nordson EFD's MicroCoat® system uses LVLP (Low Volume, Low Pressure) technology for precise, consistent lubrication of stock or dies. Get precise, exact coverage, extended tool life, and up to 85% oil savings. See what MicroCoat users have to say.
See the Magslide® Conveyor in Action at IMTS Booth # N7358MagLift
Bunting® Magnetics Co., the leader in moving, removing and holding metal, is showcasing its MagSlide® Chip and Parts Conveyor at IMTS 2016. Materials that punish traditional belted and steel-hinged conveyors—oily parts, jagged scrap, and other abrasive materials—are easily and effectively transported with the company's MagSlide®. Learn more at BuntingMagnetics.com.
Hot Off The Press
The authority on late-breaking metalforming news.
Stay ahead of the curve!
> Today's News
> Moeller, Metal Working Supply Open TN Service Center
> Miller and Hobart to Host Welding, Heating Tech. Conference
> Laser Mechanisms Opens Hermosillo, Mexico, Office
> Abstracts Sought for Great Designs in Steel 2017
Sponsors
Machining Without Coolant
Replace messy mist systems and improve dry machining with clean, cold air! EXAIR's Cold Gun Aircoolant System improves tolerances, tool life and production rates by cooling with 20°F air. The Cold Gun is ideal for tool sharpening, drill and cutter grinding, milling, band sawing, more.
Epicor ERP Delivers Choice, Flexibility and
Agility
EpciorEpicor® Software Corporation is a global leader delivering inspired business software solutions to the manufacturing, distribution, retail and services industries. Epicor enterprise resource planning (ERP) and production control software (MES) enable manufacturers to drive increased efficiency and improve profitability. To learn more, visit www.epicor.com.
Improve Die Design Productivity Through Digitalization & Automation
In this webinar we will discuss and demonstrate how NX™ Progressive Die Wizard software transforms the tooling development process with advanced automation. Knowledge-driven applications for tooling design and manufacturing. This level of knowledge driven automation improves overall productivity, accelerates the process, reduces waste and cost and improves quality.
You Ought To Know...
> Survey Shows Positive Outlook for Manufacturing, Automotive Sector
A new survey from RSM finds that middle-market manufacturers and automotive suppliers are optimistic about business growth, even as automotive suppliers face pressures such as OEM pricing, changing requirements, erratic schedules and rising employee costs. And, for sure some sectors–energy, agriculture and general industrial manufacturing—are experiencing a decrease in demand.
Some 70 percent of manufacturers in the United States and around the world expect an increase in operating profits, and more than half expect to increase their workforce; 75 percent expect to increase revenues. In the United States, 40 percent self-identify as thriving and 55 percent say they are holding steady.
Read more.
Sponsors
PFA Makes Die Positioning Easy
PFA Mechanical Die Lifters are actuated by hand to the lifted position prior to die insertion and then released to lower the die. They are portable and can be taken from press to press. These units can be used in multiple presses, greatly reducing QDC equipment costs.
Dexco Structural Coil Racks
…are engineered to handle loads in excess of 80,000 pounds per level and provide more than 40' of vertical storage. Individual cradles safely accommodate variations in coil width and weight. Wide flange beams deliver greater strength and durability as compared to roll-formed steel. Learn more at www.dexcoracks.com.
Visit EuroBLECH 2016: 1,600 Exhibitors from 40 Countries, Live Machine Demonstrations
The international sheet metal working industry will meet again this fall in Hanover, Germany, from October 25 to 29. Visit EuroBLECH, the World's No. 1 Sheet Metal Working Technology Exhibition! Experience live machine demonstrations and the latest international industry trends. Buy your ticket for EuroBLECH 2016 now!
Sponsors
Start Planning for Manufacturing Day
Coming up quickly is the fifth annual edition of Manufacturing Day, October 7, meant to inspire the next generation of manufacturers. Hundreds of industry-leading organizations will do their part to promote careers in manufacturing to students, community leaders and others. For ideas on how your company can participate, visit the Manufacturing Day website.
Get Answers to Your Most "PRESSING" Questions
You won't want to miss the enhanced 2016 Servo Press Technology Experience, presented by MetalForming magazine and PMA, taking place on October 5-6 in Nashville. This new conference will feature state-of-the-art servo technology used in presses, transfer systems, coil-feed lines and more. Aimed at engineers and technicians working in metalforming plants, the conference will provide technical presentations and case studies describing how modern servo-based equipment can help stampers improve productivity and quality. Space is limited at this premier conference, so register today!
Metal Stamping Technology and Tool
& Die Conference
The inaugural Metal Stamping Technology and Tool & Die Conference will be held in Chicago, IL on December 6-7, 2016. It will offer industry-leading intelligence to professionals from both the metal stamping and tool & die communities to learn from one another, share experiences, and gain new insight into emerging, evolving and maturing technologies.
In This Issue:
> Automotive Outlook: Challenges Abound for Tool and Die
The news is good now, but trends toward model complexity and OEMs shifting costs down the supply chain, coupled with an expected plateau in vehicle production, will require that tool and die shops gather and analyze data to shore up their sales processes.
> Servo Technolog—-Revenue Gains with Every Stroke
Nowadays, stampers in the market for a new press will find it difficult to justify NOT purchasing a servo-driven model. The process for justifying the relatively small premium for servo presses will play out at our upcoming servo-technology conference, October 5-6 in Nashville. Also on tap: how integration of related pressroom equipment enhances overall press efficiency.
What's Trending?
October
> FABTECH Show Extravaganza
> Die Design/ Development
> Welding Technology
November
> Press Controls
> Mechanical Presses
> Waterjet Cutting
December
> Awards of Excellence
> Mechanical Presses
> Waterjet Cutting
Become Involved
> Subscribe to the Magazine
> Become a Sponsor
> Post Jobs
> Media Kit
MetalForming Jobs
Plant Manager (MI) / Alcoa
Welding Inspector/Supervisor (TN) / Custom Steel Fabricators, Inc.
Director of Die Engineering (MI) / Hatch Stamping Company
Mechanical Technician (KY) / AECOM
Powered by MetalForming & PMA
See also: Industrial Magnetics, Inc., Nordson EFD, LLC, Bunting Magnetics Co., Exair Corp, Siemens Industry, Inc., PFA, Inc., Dexco Industrial Storage
