MF Xtra
October 28, 2015
Wednesday, October 28, 2015
MetalForming Xtra Newsletter
October 28, 2015
Subscribe | Become a Sponsor |
Read All About It
Creating Value Through Digital Manufacturing
Nearly every conference or seminar I attend these days on manufacturing includes a speaker covering the topic of digital manufacturing. Like it or not (and you should like it) the future is now; the so-called manufacturing revolution is here, and it impacts companies big and small.
“Manufacturing generates more data than any other sector of the economy,” says Bill King, chief technology officer of the Digital Manufacturing and Design Innovation Institute, in a McKinsey & Co. online article. “When we talk to manufacturers, they mostly throw away the data. Where they keep it, they don’t know what to do.”
“The digital revolution will be fueled by unprecedented growth in two areas,” adds McKinsey & Co. executive Richard Kelly: “Electronic connections among people and things, and the instant availability of massive amounts of data. How will this revolution change the way people look at challenges and create value?”
Here’s the article.
Sponsors
Picking up what Vacuum Cups Cannot
Industrial MagneticsTransporter®LP magnetic end-of-arm tooling is designed to transfer metal blanks, stampings and parts in automated and robotic applications. Engineered with powerful Rare Earth magnets, they will hold parts during power loss, minimize part shifting, provide more options for picking up perforated or odd parts, and reduce shop air costs significantly compared to vacuum cups.
Success is programmable.
Schuler ServoDirect Technology.
Schuler Schuler’s reliable ServoDirect Technology is proven globally. Invest in your future with a business strategy that competes on quality with higher throughput. Gain flexibility and credibility with your customers by implementing a change in your overall process to get better bottom-line results. The payback is in your future.
Hot Off The Press
The authority on late breaking metalforming news.
Stay ahead of the curve!
> Today's News
> Linear Transfer Automation to Move
> Spanish Press Company Joins Nidec Minster
> Yaskawa Motoman Earns Honda Supplier Award
> Metalformer Introduces 24-Hr. Prototyping Service
You Ought To Know...
> Webinar: Using Data to Create a Competitive Advantage
In this archived 1-hr. webinar, Rick Delawder, CEO of SWD Inc., a continuous-improvement-minded provider of metal-finishing and fastener-sorting services, describes how he caught a vision of using data to become more competitive by learning how Amazon leverages “big data.” Now, new data-discovery and analysis software allows SWD management to unlock new pathways to improved performance, and serves as the foundation for its customer-communication strategy of the future.
Listen in as Delawder discusses how he had struggled to use the data that had been lying around his shop. Now, however, thanks to SWD’s new analysis software, Delawder can put the data into a form where his team can use it to make decisions that improve operations, pricing and customer communication. He finishes by describing how he has “created a culture of analytics.”
Sponsors
Tonnage Monitor Includes Signature Analysis
The Helm PTM-4500 Loadgard combines tonnage monitoring, signature Analysis and SPC charting with batch, part counters in one system. With full-color touch screen and Resolver input, the PTM provides thru-the-stroke monitoring with high and low tracking alarms for all types of presses. FABTECH Booth S4556
Stock Lubrication
Cleans Up Its Act
Unist Stock lubrication can be the ugly side of metal forming with messy presses and sloppy, wet floors. Luckily, those days are over. Uni-Roller systems from Unist use patented, internally-fed rollers to deliver smooth and consistent lube to one or both sides of the stock with no over-application or mess.
Increasing Capacity Face-Off: Infinite Versus Finite Scheduling
Implementing correct scheduling software might be one of your most important decisions when it comes to improving operational efficiency. Download this feature to learn about the pros, cons and benefits of infinite versus finite scheduling.
In This Issue:
> Robotic Welding Cells--Out with the Old
...and in with the new at Ariens Co., where several new automated welding cells have spurred a 25-percent leap in productivity, while slashing the time lost to maintenance, repairs and tech calls.
> Five Simple Strategies to Do More for Your Customers
Vertical integration holds the key to winning over new customers in the highly competitive landscape occupied by metalformers and fabricators.
What's Trending?
November
> Mechanical Presses
> CNC Punch Presses
> Pressroom Safety
December
> Press Feeds
> PMA Awards of Excellence
> Laser/Waterjet Cutting
January
>Pressroom Automation
> Press Feeds
> Laser Cutting
Become Involved
Subscribe to the Magazine
Become a Sponsor
Post Jobs
2015 Media Kit
MetalForming Jobs
Progressive Tool & Die Maker (CT) / Bridgeport Fittings
3rd shift Tool & Die Maintenance (TN) / ITW CIP
Aircraft Worker - Sheet Metal (NC) / J.K. Hill and Associates
Sheet Metal Punch Operator (IA) / Greater Machining & Manufacturing, Co.
Metal Stamping Die Designer - Manufacturing (MI) / Concept Tooling Systems
Sponsors
Magnum Press Redesigns
Their Website, Now Optimized
for Mobile Devices!
hydraulic press manufacturer Magnum Press Inc., the market leading high speed hydraulic press manufacturer, has just launched their new mobile-optimized website, http://www.magnumpress.com/. Whatever your application: bench-top or floor-standing C frame; 2 post or 4 post; from standard to custom; 2 ton to 1500+ ton; our new site will help you find the right hydraulic press for your needs!
Climb to New Heights
in Metalforming at EDA!
Join Precision Metalforming Association (PMA) from November 9-11 in Chicago for the highly anticipated Executive Development Academy (EDA) to support you as you build, lead and sustain your company, now and in the future. Key topics for discussion include business succession, R&D tax credit, talent retention and leadership excellence. Visit the event website or contact Allison Grealis at 216-901-8800 for more information. Space is limited for this exclusive engagement, so register today!
Powered by MetalForming & PMA
See also: Industrial Magnetics, Inc., IQMS Manufacturing ERP & MES, Schuler Incorporated, Helm Instrument Co., Inc., Magnum Press, Inc., Unist, Inc.
YOUR NAME *
EMAIL *
WEBSITE
