Hot off the Press
Alcoas Next-Gen Aluminum-Production Process Improves Formability
Friday, December 5, 2014
Alcoa has unveiled its new Micromill process that promises to dramatically change the microstructure of aluminum, allowing the production of an aluminum alloy for automotive applications that reportedly has 40 percent greater formability and 30 percent greater strength than the incumbent aluminum, while meeting stringent automotive surface-quality requirements.  Additionally, automotive parts made with Micromill material will be twice as formable and at least 30 percent lighter than parts made from high-strength steel, according to Alcoa, and Micromill reduces the time to transform molten metal into aluminum coil from 20 days to 20 min. Learn more here.
YOUR NAME *
EMAIL *
WEBSITE
