Automotive Stamper to Add Plant-Wide Lubrication System
February 1, 2015Comments
Austin Tri-Hawk Automotive, Austin, IN, will install a Pro-Mix V proportional lubricant-mixing system from Industrial Innovations, Grandville, MI.
It also will install the necessary piping, as well as Industrial Innovations’ Spra-Rite systems of manifolds and Z-series nozzles. The system will deliver lubricant directly to the firm’s four Aida press lines—1500- and 2000-ton transfer presses and 200- and 400-ton progressive-die presses.
See also: Aida-America Corp., Industrial Innovations, Inc.
Technologies: Lubrication
