The Science of Forming
Two More Tools for the Troubleshooting Toolbox
By: Stuart Keeler
Saturday, October 1, 2011
Demand for dimensionally consistent stampings is increasing. Drivers include more accurate alignment for laser welding, stacking variation of multiple stampings, minimizing visual gaps and robotic processing. Stampings of thinner-gauge materials with increased strength for weight reduction predictably have greater springback and reduced stretchability. These higher-strength materials also generate localized gradients (narrow peaks) of deformation, accompanied by localized reductions in thickness. Springback and deformation gradients are leading causes of dimensional variations that must be minimized and controlled.
An obvious first approach is to tighten controls on the material properties and the other 40 or so inputs to the forming process. Next, stampers should implement tighter process-control procedures, although the job of establishing control charts and monitoring 40-plus inputs can prove daunting, as most difficult problems arise due to the interaction of three or more variables.
For example, consider the change in material movement from the binder area over the die radius, caused by the interaction of die wear, sheetmetal and lubricant thickness and temperature in the deformation zone. While the change in each individual input might be within normal specifications, it is the synergistic interaction that can cause sheetmetal flow to range from free flow to lockup.
A useful tool for troubleshooting problems with dimensional variation is the portable (now available as battery-operated handheld units) ultrasonic thickness gauge (UTG). With the correct UTG frequency, probe size and delay line, sheet thickness can be measured to within ±0.0001 in. Examples of how stampers can use a UTG:
1) Checking the thickness variation of incoming coils or blanks. A small length of steel at the head and tail of a coil may have a different thickness than the remainder of the coil, depending on the specific processing at the producing mill or service center. Some press shops remove these coil ends before the material reaches the press line. The UTG provides a quick read of thickness anywhere in the coil, particularly where micrometers can’t reach. At the other end of a press line, a UTG can measure critical thickness locations on finished stampings and internally record several thousand readings for further data analysis. Sometimes the UTG will detect a wedge-shape thickness profile from one blank edge to the other.
2) Circle grids can be etched in the blanks and used to display deformation patterns throughout the stamping. The constancy-of-volume rule says that a given combination of surface deformation must result in a specific amount of change in material thickness. A UTG can track variations in thickness deformation to flag changes in surface deformation. Circle grids are not needed until more detailed problem solving is required.
3) Draw beads are very effective in controlling material flow through the binder and over the die radius. Constant draw-bead restraining force is required to maintain a consistent flow. Research by the Auto Steel Partnership shows that draw-bead restraining force is proportional to the percent reduction in sheetmetal thickness measured between the material entering and exiting the bead. While a UTG cannot provide the absolute magnitude of the restraining force, it can detect changes in the force. As a real-world example, consider a right/left symmetrical die set with identical draw beads on both sides of the die. Solder strip tests show that the beads in both sides of the die had identical clearances and depths in the unloaded state. However, under production loading the bead on one side of the die caused the sheetmetal to tear, while the bead on the opposite side created loose material and buckling. The UTG measured 35-percent reduction for the torn side and only 5 percent for the loose side. Further investigation uncovered that the die was bending (breathing) under load. A cushion pin was located under the draw bead at the torn side, and no cushion pins were located near the loose side. Using data collected from the UTG, the stamper relocated the die to a zone with balanced bead-restraining forces.
4) High peak-deformation gradients often are overlooked, due to the need to apply circle grids. Instead, the stamping can quickly be scanned with a UTG until detecting a narrow band of decreased thickness. Then, a circle grid can be applied to that location to obtain surface-deformation data for corrective action.
5) When not solving forming problems, a UTG can be used to measure and track internal corrosion or abrasive wear inside piping in the press shop.
Tool Number Two
The second tool readily available for troubleshooting problems with dimensional variation is the laser thermometer gun. These noncontact devices can rapidly obtain pinpoint temperature measurements at different locations on the die or stamping. Stampers can use this data to uncover temperature variations that can cause changes in lubricant viscosity and coefficients of friction, as well as changes in die dimensions. All of these parameters affect material flow and can cause deformation patterns to change throughout the stamping.
Even small temperature changes can be disastrous. For example, consider a die producing acceptable stampings when starting production at 70 F, but which caused 100-percent breakage 15 min. later when the critical areas of the die reached 84 F. This case study can be found in the April 2004 issue of MetalForming, in the Science of Forming column called, “The Die Has a Fever?” The article discusses the simultaneous use of a UTG and a laser thermometer gun to illustrate how temperature and forming severity climbed in sync as production time increased, until the stamping finally tore.
The two handheld tools described here will help metalformers solve various press-shop problems, by obtaining meaningful data for problem tracking and solution evaluation. MF
