Hot off the Press
HVAC Sheetmetal Fabricator
Adds 4-kW Laser-Cutting Machine
Tuesday, June 30, 2009
M&M Manufacturing Co. has installed a Mazak Hypergear 2D FMS laser-cutting system at its Precision Products Division in Fort Worth, TX. The machine features a 4-kW laser to cut mild steel to 1 in. thick, as well as a material-storage tower for holding and retrieving as many as10 different sheet specifications. A pneumatic load system positions each sheet on the cutting table—with material loaded in the tower, the setup can run untended for complete shifts or over the weekend. M&M fabricates round, rectangular and spiral HVAC duct pipe and fittings, as well as sheetmetal products for roofing, ventilating and architectural applications; www.mmmfg.com. Learn more about the lineup of laser-cutting equipment from Mazak Optonics Corp., Elgin, IL, at www.mazaklaser.com
