Hot off the Press
Rollformer Equipped to Handle
Thick, High-Strength Steel
Monday, August 11, 2008
Custom Rollforming Corp. (CRC), Moundridge, KS, a manufacturer of custom rollformed products, has installed a rollforming line designed to form heavy-gauge profiles using high-strength steels. The new line, from Bradbury, features a 20,000-lb.-capacity stock reel, tooling mounted on 3-in. arbors, and a heavy-duty seven-roll straightener. A 16-pass line, it can accept coils to 24 in. wide and boasts a 150-hp output. At the exit end is an oversized part straightener and a 100-ton flying-cutoff press. Learn more about CRC at www.customrollformingcorp.com.
