Hot off the Press
Roll-Kraft Boosts CNC Machining Capabilities
Tuesday, August 16, 2005
To increase its capacity to produce tooling or the tube and pipe and rollforming industries, Roll-Kraft, Mentor, OH, has installed two new CNC lathes in its manufacturing plant, and will install a third vertical lathe by year end. This third machine is a space-saving side-by-side turning center that the firm can use to rough-out parts on one side and finish-machine on the opposite side. Learn more at www.roll-kraft.com.
