Hot off the Press
Mi-Tech Steel Orders Slitting-Inspection Line
Friday, August 29, 2003
Mi-Tech Steel, Inc., Louisville, KY, a flat-rolled-steel distributor and coil processor, has awarded Braner/Loopco, Schiller Park, IL, an order to supply a double slitting and coil-surface-inspection line. The line will be installed at the new Mi-Tech facility in Jackson, MS. The line is capable of top and bottom surface inspection and slitting of coils weighing to 60,000 lb. in widths to 72 in. It can process surface-critical class 1 galvanized and bare cold-rolled steel coils in thicknesses from 0.015 to 0.125 in. at speeds to 1000 ft./min. This will be the seventh Braner/Loopco slitting line installed for Mi-Tech. For more, visit www.braner.com.
