Hot off the Press
Boeing Orders Laminated Aluminum Sheet
Monday, January 21, 2002
Bolsan Company Inc., Pittsburgh, PA, will provide laminated aluminum sheet to Boeing Commercial Airplanes, Wichita, KS, and Seattle, WA. Delivery of the sheet begins this month-Boeing-Wichita will convert the material into shims and spacers for closing small gaps in complex fabricated parts. Each sheet of aluminum consists of glued layers as thin as 0.05 mm. Working with the laminated sheet allows Boeing workers to make fine adjustments to shim thickness by peeling a individual layers.
