Hot off the Press
Schuler to Supply Heavy-Duty Laser to GM-Canada
Monday, January 14, 2002
Schuler Inc., Canton, MI, has received an order for a second Pedilas heavy-duty laser system from General Motors of Canada, Ltd., London, Ontario. The new system, to be installed early in 2002, will complement a nearly identical system purchased by GM-Canada seven years ago. Both units can cut steel plate to thicknesses of 1 in. and produce bevel cuts in angles to 45 deg. The Pedilas laser is a five-axis bridge system with and over-and-under, dual-pallet load/unload capability; a 20-by-8-ft. cutting envelope and a 4-kw CO2 laser. The totally enclosed system also has debris-collection capability.
