Zero-Drip Nozzle Eliminates Lubrication Waste
July 22, 2013Comments
Fluid application is controlled through pressure, time, degree of pattern and electronic programming of a simple HMI. The design provides easy interchangeability of the spray tips for a variety of spray angles and volumes. For example, at 40-PSI water pressure, flow is 0.1 gal./min. at a 25-deg. angle; 0.2 gal./min. at 65 deg.; and 0.4 gal./min. at 110 deg.
The spray nozzles are available in brass, stainless steel or plastic, with tubing choices of 1⁄8-, 3⁄16- and ¼-in. dia.
Industrial Innovations: 616/249-1525; www.industrialinnovations.comTechnologies: Bending
There are no comments posted.Sheet Metal Folding and Forming
Monday, July 7, 2025
Cutting, Bending and Welding Equipment Plus Related Software
Monday, August 5, 2024
Creative Approaches to Common Press Brake Challenges, Part 1...
