Welding and Cutting Systems
October 1, 2015Comments
Esab
Booth N6074
Esab, Florence, SC, showcases new welding and cutting systems and provides live demonstrations. On display are the Warrior 400i MV CC/CV, a multi-voltage, multi-process welding system that automatically accepts 230-V three-phase or 460-V three-phase power; the heavy-duty Warrior Feed 404 HD that reportedly can reduce cost of operation by 30 to 60 percent compared to other leading brands of feeders due to its drive-roll design, which combines two lower gear-driven rollers with two upper idler/smooth pressure rollers; and the Aristo Feed 4004i HD heavy-duty feeder, which has the same drive-roll design as the Warrior Feed 404 HD.
Also on display, the ET 220i AC/DC and ET 301i AC/DC inverter-based welding systems, which offer full digital control of the gas-tungsten-arc welding arc and weigh just 29.5 and 35.9 lb., respectively.
See also: ESAB Welding & Cutting
There are no comments posted.Turck Introduces Automated Weld-Water Detection System
Wednesday, June 25, 2025
AWS Releases Updated Standard for Welding Terminology
Wednesday, March 19, 2025
AI for Resistance Welding? Six Predictions on its Positive I...
Wednesday, February 19, 2025
