Three-in-One Arc-Welding System
October 1, 2011Comments
Thermal Arc, St. Louis, MO, has launched the first in a series of multi-process, fully integrated portable welding machines designed to take on many gas-metal-, shielded-metal- and gas-tungsten-arc welding applications. Its introductory Thermal Arc Fabricator 181i system is a portable powerhouse that delivers 180 A of welding output power.
Weighing less than 33 lb., the compact machine optimizes portability. It’s ideally suited for light fabrication, maintenance and repair welding and educational training. Included is a detailed weld setup guide for optimum welding performance over a range of materials and shielding gases; digital meters with preview; infinitely variable voltage control; metal feed plate with quick-change drive rolls; and a receptacle for connecting remote-control devices or a spool gun.
Thermal Arc: 636/728-3000; www.thermalarc.com
See also: Victor Technologies Group, Inc.
