7th-Generation Front-Rear Mount Servo Transfer
October 1, 2009Comments
Linear Transfer Automation introduces its 7th-generation front-and-rear-mount servo transfer system, redesigned with an aluminum Z-box design that is lighter and stiffer than previous generations. The lighter, stiffer actuators allow for quicker, smoother payload transfer. Use the systems to turn any style of press, new or old, into a fully programmable transfer press. The unit parks up and out of the during die change or while running progressive dies, and has fully independent head control and can run many variations of motion profiles. It can easily be adapted to accept takeover or emergency work from another transfer system.
See also: Linear Transfer Automation Inc.
