Magnetic Products, Including End-of-Arm Tooling
March 1, 2008Comments
Industrial Magnetics, Inc., Boyne City, MI, will demonstrate its Transporter family of magnetic end-of-arm tooling, designed to replace vacuum cups and offer longer life, better holding values and failsafe design in the event of air loss. Also on display will be PowerLift rare earth lift magnets, featuring a rotary on/off handle and requiring no power to use. These are available in capacities to lift as much as 4400 lb. of nonflexing steel. The company’s entire lineup of welding products will be available for demonstration, including squares, angles, magnetic grounds and clamps.
See also: Industrial Magnetics, Inc.
