Zero-Drip Nozzle Eliminates Lubrication Waste
July 1, 2013Comments
Fluid application is controlled through pressure, time, degree of pattern and electronic programming of a simple HMI. The design provides easy interchangeability of the spray tips for a variety of spray angles and volumes. For example, at 40-PSI water pressure, flow is 0.1 gal./min. at a 25-deg. angle; 0.2 gal./min. at 65 deg.; and 0.4 gal./min. at 110 deg.
The spray nozzles are available in brass, stainless steel or plastic, with tubing choices of 1⁄8-, 3⁄16- and ¼-in. dia.
Industrial Innovations: 616/249-1525; www.industrialinnovations.com
See also: Industrial Innovations, Inc.
Technologies: Lubrication
There are no comments posted.Mexico Stamping Technology Webinar Series 2025: Day 2
Thursday, April 3, 2025
Synthetic Stamping Lube Saves the Day
Brad Kuvin Monday, February 10, 2025
