Automotive Stamper to Add Plant-Wide Lubrication System
February 1, 2015Austin Tri-Hawk Automotive, Austin, IN, will install a Pro-Mix V proportional lubricant-mixing system from Industrial Innovations, Grandville, MI.
It also will install the necessary piping, as well as Industrial Innovations’ Spra-Rite systems of manifolds and Z-series nozzles. The system will deliver lubricant directly to the firm’s four Aida press lines—1500- and 2000-ton transfer presses and 200- and 400-ton progressive-die presses.
See also: Aida-America Corp., Industrial Innovations, Inc.
Technologies: Lubrication
Sustainability Improves ESG Reporting Through Better Lubrica...
Troy Turnbull Friday, April 1, 2022
Tuesday, January 4, 2022
Industrial Innovations Names Rodney Yeomans Director of Sale...
FloaterCoater Designed to Lubricate Heavy-Duty Stamping
Wednesday, August 18, 2021
Die-Lube Systems—Line-Side and Plant-Wide
Monday, July 26, 2021
