Feed-Straightener Combo Equipped for Easy Cleaning
October 1, 2013Comments
CHS Automation/Pneumatic Feed Service
Booth S4517
CHS Automation/Pneumatic Feed Service, Roseville, MI, will feature a DRFS-530 servo feed-straightener combination unit with a seven-roll pull-through straightener, powered pinch rolls, powered passline adjustment and piloting straightener design. A high-lift upper bank eases cleaning. The feed-straightener is a part of a complete 20,000-lb.-capacity by 30-in.-wide spacesaver coil-feed line and includes a Bosch-Rexroth/Indramat Indramotion servo control RFX platform.
Also in the booth, Pneumatic Feed Service will showcase a remanufactured servo-roll feed. Only half of the machine will be reconditioned, to illustrate the firm’s used-equipment reconditioning capabilities.
www.chsautomation.com
See also: Pneumatic Feed Service
Technologies: Finishing
There are no comments posted.Vertical Blast System Tackles High-Volume Sheet Metal Surfac...
Monday, November 11, 2024
Daubert Cromwell Appoints Rodrigo Martinez Mexico Country Le...
Monday, March 18, 2024
