Automobile Press Line with Automation System
October 1, 2016 Strothmann Machines & Handling GmbH
Booth C14108
The FeederPlus linear robot system from Strothmann, equipped with additional rotating axes that can orient blanks during transfer, promises to outperform conventional six-axis robots in press-automation applications, in terms of speed and flexibility. The concept, proven in many tandem press lines, can perform rotary motions in the B axis—orienting the rotating arm. Due to a laterally offset design, the diagonal speed component can be eliminated. The unit suits operation in press gaps measuring at least 6500 mm and as large as 11,000 mm; maximum load is 125 kg. Repeatability, ±0.25 mm.
Also on display: the CompactTransfer system that makes orientation stations between presses unnecessary. The system picks up the parts, orients them and places them in the following press all by itself.
www.strothmann-us.com
See also: Strothmann Machines & Handling GmbH
Technologies: Fabrication, Pressroom Automation
New Cobot Welder Increases Productivity, Improves Job Satisf...
Tuesday, August 16, 2022
Fanuc Mexico Opens New Headquarters in Aguascalientes
Thursday, July 14, 2022
RoboDK TwinTool Provides Automated Tool Calibration for Indu...
Wednesday, June 29, 2022
