Live Demos of Cold Saws, Ironworkers, Pipe Notchers and Hydraulic Presses
July 19, 2021Comments
Scotchman Industries
Booth A3526, A3625
Scotchman will perform live product demonstrations
continuously throughout the show. Equipment on display includes the CPO 350
AutoLoader circular cold saw with the new, Clear Awareness Barrier with safety
interlock switch. These new features provide extra safety for sawing while
allowing the operator to visually monitor the saw in-action. The
variable-speed, semi-automatic CPO 350 can be coupled with an auto-loading
material-feed system to create a fully automatic sawing system that cuts
multiple lengths of tube (max. 3-in. dia.). The saw can rub unlimited cut lists
in lengths from 0.5 in. to 23 ft.
Also shown: the Scotchman 5014-ET ironworker, reportedly the world’s only 50-ton hydraulic ironworker with a three-station turret. The revolving turret accepts as many as three different punch sizes that can be changed in seconds, thus reducing setup time and increasing productivity. This ironworker can punch a 13/16-in. hole in a ¾-in. plate, and comes standard with a 4-in. angle shear, 14-in. flat bar shear and rectangle notcher.
Other ironworkers, cold saw, pipe notchers, hydraulic presses and measuring systems also will be on display.
See also: Scotchman Industries, Inc.
Technologies: Cutting
There are no comments posted.Cordless, Low-Profile Magnetic Drilling Machine
Thursday, July 31, 2025
CuttingBLM Group Opens Service Branch in France
Thursday, July 11, 2024
