Alro Steel Adds Tube-Cutoff System
September 1, 2016Alro Steel has added a new Hautau RC60 tube-cutoff system at its Potterville, MI, location. Benefits reportedly include ID/OD chamfers of both ends, high production speeds and precision tolerances. The system can cut carbon steel, stainless steel, aluminum, brass, bronze, copper and alloy tubing as large as 6.7-in. dia.
Alro Steel distributes metals, industrial supplies and plastics, and has more than 60 locations across 12 states.
Technologies: Cutting
Mazak Optonics Showcases New 15-kW Laser Cutting Machine at ...
Wednesday, May 4, 2022
Tenere Opens New Sheet Metal Fabrication Plant in Nuevo León...
Tuesday, April 26, 2022
What Cutting Method Should I Choose?
Thursday, March 31, 2022
