Deep-Draw Stamper Adds 4-kW Fiber Laser
November 1, 2012CommentsAtaco Steel Products, Cedarburg, WI, has acquired a 4-kW fiber-laser cutting system, along with a 66,000-lb.-capacity material-feed tower, from Cy Lasers. The machine is the second Cy fiber-laser cutting machine installed at Ataco. It will be housed in the firm’s recently completed 35,000-sq.-ft. expansion.
See also: ATACO Steel Products Corporation
Technologies: Cutting
