Quicker Punch-Length Adjustment with Adjustable Thick Turret Canisters
October 1, 2012
Mate Precision Tooling
Booth 3720
Mate Precision Tooling, Anoka, MN, will introduce its Rapidset adjustable thick turret canisters for use with Mate Original Style and AMX punch-press tooling. Rapidset—also compatible with Amada Standard, Amada ABS and Wilson Standard tooling styles—provides quick tool changes and makes punch-length adjustment faster with existing tooling inventories. Features: non-rotating clamping head with easily adjustable clamping screw for setting punch length; textured Gription canister for ease of handling; and a preloaded self-contained spring pack that provides consistent stripping pressure, die penetration and reduced slug-pulling. Available in A and B station canisters.
Also on display: The new XMT12.7A adjustable-length punch for Euromac XMTE10 Multi-Tools. The design allows punch-length adjustment by rotating the punch head. When coupled with XMT12.7A’s standard high-speed steel punches, grind life can be tripled.
www.mate.com
Industry-Related Terms: Die, Penetration, Stripping, Turret
Technologies: CNC Punching
