Page 15 - MetalForming Magazine June/July 2022 80th Anniversary Issue
P. 15
Destaco Updates Its 800 Series Manual Clamps, Debuts Front-Mount-Base Manual Clamps
Destaco, Auburn Hills, MI, has com- pleted quality enhancements for three models within its 800 Series family of manual clamps. Receiving the most exten- sive quality enhancements: the Model 802-U clamp, which now includes an
upgraded air cylinder that ensures that the clamp’s exerting force is less than the maximum holding capacity when oper- ated at normal pressure, extending service life; new composite bearings on the trun- nion mount and cylinder pivot point that
eliminate metal-to-metal contact while requiring no lubrication; and a redesigned clevis bolt, along with increased rivet and pre-stop diam- eters, that also increase longevity.
In addition, the firm has expanded the range of its horizontal and vertical toggle-lock manual-clamp product line with the introduc- tion of a front-mount-
base model. The compact, space-saving design offers users additional flexibility in their workholding applications. The front-mount option is offered on four man- ual clamps for use with vertical and hori- zontal handle action.
Destaco: www.destaco.com
Efficient Wheel
Manufacturing
Reaches a New Level
Leifeld Metal Spinning GmbH has devel- oped a new machine, the Leifeld WSC Flex, for manufacturing rims using a flow- forming process. To shape the inside and outside rim surfaces, the machine employs internal rollers in place of an operator’s hands. Because the process works without tools, the user gains maximum flexibility
Our selection of Permanent and Electro magnet lifts cover a wide range of steel lifting applications. We also specialize in custom lift solutions designed specifically for your application.
12 MetalForming/June/July 2022
