Page 17 - MetalForming Magazine June/July 2022 80th Anniversary Issue
P. 17
the erosion height.
In testing, iWire working with ISPS pre-
vented wire breakage on a part with numerous features with varying erosion heights. The cut started at a standard spool speed, then when the cutting height lessened, the speed slowed. As a result, wire savings equated to about 480 m or 0.2 kg, and overall process time dropped by 30 percent.
GF Machining: www.gfms.com
New Rite-Hite
Low-Speed Fan
Spreads Cooling Air
85 ft. in All Directions
Rite-Hite, Milwaukee, WI, has added the Revolution LT high-volume, low-speed fan to its expanding industrial-fan lineup. Available in 8- to 24-ft. dia., the fan’s
80
eating
Stamping / Fabrication / Welding Assemblies / Design
daytonrogers.com
What challenge can we solve for you?
Speak to our team about your next project.
(833) 234-1659 solutions@daytonrogers.com
est. 1929
oger
F
Dayton
company’s Intelligent Spark Protection System (ISPS), both of which reside in the company’s Uniqua control.
Knowing the exact location of a spark allows iWire to automatically adapt the wire-spool speed accordingly, reducing the chances of wire breakage during unat- tended operations when cutting parts with steps and other features that vary
l
Minnea
R
s
ACTURING CO
R
MANUF
A
polis, MN
uture of the Metal orming Industry Since 1929.
o
orming the Fu
F
Raise the bar with Dayton Rogers.
Da
yton Rogers w
14 MetalForming/June/July 2022
asf
ounded in 1929 with the vision of cr
lington, TX Columbia, SC Columbus, OH
Ar
four-blade design comes with a single fan controller that uses a 4-in. touchscreen for operation (on/off, speed adjustment, and forward/reverse settings). The Rev- olution LT pulls air from above the fan and pushes it down in toward the floor in a conical shape, spreading to 85 ft. in all directions from the center of the fan. This cone shape allows the fan to cover as much as 22,000 sq. ft. without leaving a dead air spot in the center.
Like other fans in the Revolution lineup, the Revolution LT provides consistent air movement with the shape of its blade. It’s this shape—not the number of fan blades—which creates consistent air move- ment across the entire fan diameter. Rite-Hite: www.ritehite.com
