Page 10 - MetalForming Magazine March 2022
P. 10
Automatic Feed Debuts New Coil- Feed Lines, and the Flexible Edge Stacker for Surface- and Edge-Critical Blanks
Automatic Feed Co. (AFCO), Napoleon, OH, has introduced its Pro Series coil-pro- cessing lines aimed at Tier automotive suppliers processing advanced high-strength steels and aluminum alloys for nonsur- face-sensitive automotive applications. The lines each comprise a single reel and coil cart, peeler, straightener, threading table and press feed, and can directly feed coil stock to a stamping press or a laser- blanking system. The controls package enables integration between the press and the coil line and includes a pedestal-mount- ed HMI with touchscreen control.
Pro Series systems come in three sizes,
LIFTING
with coil-width capacity of 40, 60 or 80 in. All models can feed a minimum coil width of 4 in. and sheet thickness from 0.02 to 0.25 in. at speeds to 160 ft./min. Use the machines to feed aluminum grades with yield strengths to 350 MPa and steel to 1200 MPa, with maximum coil weight of 60,000 lb. and 80-in. max-
imum coil o.d. The units feature AFCO’s state-of-the-art leveler technology and include a straightener calculator to help operators adjust straightener settings. The uncoiler reel features a servo motor for optimum back-tension control.
Also new from AFCO: The Edge Stacker, featuring a servo-driven overhead conveyor
AND MORE
Our selection of Permanent and Electro magnet lifts cover a wide range of steel lifting applications. We also specialize in custom lift solutions designed specifically for your application.
INDUSTRIAL MAGNETICS, INC.
231.582.3100 • 888.582.0822 • WWW.MAGNETICS.COM MORE THAN A MAGNET COMPANY
8
MetalForming/March 2022
