Page 11 - MetalForming Magazine March 2022
P. 11
that transports blanks and precisely drops them into ice-cube stacks while maintaining premium edge quality. Use the stacking system on blanking or cut-to-length lines processing surface-sensitive steel or alu- minum, as well as on laser-welding lines. Material capacity, 0.5 to 3.0 mm thick; blank-size capacity, 100-4000 mm long by 300-2134 mm wide. The stackers are available as single- or double-station units and can be equipped with switchable per- manent magnets, a vacuum system or as a hybrid version that includes both. Choose from a variety of stacking-guide options.
Edge stackers typically include an exit conveyor with sheet lifters, multiple guide assemblies and rotating stacking carts with scissor lifts. Select from several oper- ating modes including single stacking for a single stack per station; continuous- mode stacking for non-trapezoidal blanks; alternate-mode stacking for trapezoidal blanks; dual side-by-side part stacking; and dual end-to-end part stacking. A Soft Piling feature, unique to AFCO’s motion- control technology, protects the leading edge of parts; for an added level of edge protection, add the Stop & Drop stacking feature.
Automatic Feed Co.: www.automaticfeed.com
Aida’s Newly Designed Unitized- Frame NSX 110- Metric-Ton Press Hits 300 Strokes/Min.
Aida-America has introduced a newly designed NSX 110-metric-ton, unitized- frame mechanical stamping press, rated for press speeds from 120 to 300 strokes/min. with a 65-mm stroke. The NSX features a low-deflection, one-piece frame and a low-deflection cast-iron slide. Zero-clearance roller-type slide guides and counter-rotating eccentric shafts help ensure accuracy and consistent high-vol- ume production.
Other features include hydraulic overload protection; a choice of plug-and-play Win- triss, Link or Rockwell Allen- Bradley controls; and eight programmable limit-switch channels.
Aida-America: www.aida-global.com
It used to skew and chatter.
This press applies up to 3000 tons to form composite automobile panels. Delta’s RMC does multi-axis control of position and pressure to keep every moving part in perfect synchronization.
Look to Delta RMC motion controllers and graphical RMCTools software
to make complex motion design easier, smoother, and more precise.
Visit our website for the full Wuxi LANLI Machine Tool Co. case study or one about your industry or application. Watch our training videos and see how Delta motion can make your application work in perfect, precise harmony.
1 to 50 Axis
Now it runs like a Swiss watch.
