Page 20 - MetalForming November 2014
P. 20
New Stamping Press
Press Controls For All Presses
One Source
One Solution
Toledo Integrated Systems
Press Pilot 150 Control
We Provide Solutions For...
Mechanical Presses Hydraulic Presses Forging Presses Transfer Presses
Maximizer TPC (Total Press Control)
Toledo Integrated Systems Toledo Transducers, Inc.
www.ToledoIntegratedSystems.com 800-T-Toledo 419-867-4170
Additionally, to accelerate the press’s return on investment, Arnold ear- marked two additional fabricated parts to be converted over to hard tooling for stamping on the new press.
“All told, we’re expecting a 2.5-year payback on the press once Genu-Pro enters full production early in 2015,” he says.
One of the existing fabricated parts moved to stamping is a 2- by 2-in. flat part that is assembled into one of the firm’s post-operative knee braces. Pro- duction quantities average 5000/mo. Compared to laser-cutting the part, from 0.032-in. Type 301 stainless steel, stamping reduced piece-part costs by $0.35, a 40-percent savings, “so there was no problem justifying the tooling costs,” Arnold says. He also notes that to better-facilitate making the part on the Sutherland press, the firm switched from a full-hard stainless-steel alloy to half-hard.
“We felt that the original full-hard part was over-engineered,” Arnold adds, “and that moving to a half-hard alloy would increase the life of our stamping tools.”
Arnold also moved a second part for the same post-op brace from fabri- cation to stamping, this one a much larger gear-shaped part used to set flex- ion and extension stops as the brace is worn by patients. This part, actually two stamped parts (left- and right- hand), is Type 304 stainless steel; a plastic part fits between the two stamped parts in assembly. Why the move from fabrication to stamping?
“The teeth of the two stamped stainless-steel parts must align per- fectly to ensure repeatable, comfort- able operation of the brace,” says Arnold. “While we definitely were able to assemble quality braces used fabri- cated parts, we thought that stamping the parts would make the assembly task faster and easier, and we were right. In the end, running the Suther- land press at 35 strokes/min. to stamp the parts compared to 45 to 60 sec. to fabricate each part reduced piece-part cost from $2.00 to $0.60. That’s a huge savings.” MF
YOUR PRODUCTIVITY BOOSTER
MOLDDESIGN| DIEDESIGN| MACHINING
www.CimatronTech.com 877.596.9700
18 MetalForming/November 2014
