Page 94 - MetalForming October 2013
P. 94
A
Previews
UNCOIL
THE POWER.
We specialize in:
Strip Connector Alloys, Copper, Brass, Phosphor Bronze, Beryllium Copper, Stainless Steel, and Aluminum Strip
Thin gauges and narrow widths delivered within hours if needed!
Services Available:
Precision Slitting • Tension Leveling Traverse Winding • Pre coating: tin, nickel, or precious • Logistics & Border Crossing
ABC Metals, Inc.
Logansport, IN • Pharr, TX • El Paso, TX 800.238.8470 • fax 547.753.6110 • abcmetals.com
Straightsides and C-Frames, and a
Full Menu of Remanufacturing Services
The Heim Group Booth 4363
In the Heim booth, a before/after remanu- factured press and a battery of other serv- ices will be displayed. The Chicago, IL com- pany maintains a con- siderable inventory of remanufactured press- es, plus offers the abil- ity to retrofit or rebuild any Heim, Rousselle or select other brands of presses.
Heim engineers its
Maxi-Stamper (shown)
straightside press with
the latest CAD tech-
nology. The eccentric-
geared tie-rod are available from 300 to 1000 tons, with user- specified stroke, speed, shut height and bed area. Standard drive rating is 1⁄2 in. above bottom stroke, but other options are available.
Smaller press requirements are served by the Maxi-Stam- per II C-frame, front-to-back shaft designed presses from 90 to 300 tons. www.theheimgroup.com
Heavy-Duty Pneumatic Die Lifters
Pacesetter Systems Booth S4307
Pacesetter Systems, Inc., Valencia, CA, intro- duces its Air Glide heavy-duty pneumatic die
lifters, available with ball bearings for multidirectional movement or
cylindrical bearings for inline movement. Both models feature extra-
large, precision-ground
bearings and high quality o-ring seals to optimize lifting efficiency and durability, ensuring quick and safe die changes. Only 40 lb. of force is required to move a typical 2000-lb. die.
Air Glide lifters use standard shop air pressure and install easily in standard ANSI T-slots. Because they have no internal air bags or bladders to corrode and crack, the rollers report- edly are more resistant than other pneumatic rollers to the harsh chemicals and lubricants used in metal stamping.
Air Glide die lifters are available from stock in 5⁄8-, 3⁄4- and 1-in. sizes in lengths to 72 in.; custom lengths and metric sizes are available. www.pacesettersystems.com
AT LAST!
Large Bend Radii Corner Fills
3/4 & 1.0” I.R. CRS, CRES, Alum.
Call for a FREE sample!
M.E. Solutions • (858) 272-1300 www.MESolutionsHome.com
92 MetalForming/October 2013
