Page 9 - MetalForming December 2012
P. 9
facturers: Benchmaster, Blow Press, Cieco, Feed Lease, Greenerd Press & Machine, and Orrtech. Visitors to the site also will appreciate an expanded technical library loaded with helpful information for metal stampers; www.chpsys.com.
New IPA Knowledge Center
a Great Resource on
Perforated Materials
The Industrial Perforators Associa- tion, Milwaukee, WI, has created an online knowledge center to offer design- ers, engineers, builders and architects a comprehensive resource on perforated materials. Included is a photo library showcasing numerous applications of perforated materials, buying tips, down- loadable perforated patterns and specifi- cations, and technical articles. It’s avail- able at www.iperf.org/knowledgecenter.
Updated Website for
Coil-Handling Equipment Maker
Royalton Industries Inc., Columbia Station, OH, has updated its website with videos, an RFQ form and new tools to ease navigation; www.royaltonindus- tries.com. The firm manufactures coil cars, uncoilers, holddown peelers, coil- end joiners and other coil-handling equipment.
Facilities
Stamper Adds Tailout Feeder
to Boost Material Utilization
Tier Two automotive stamper Kalida Manufacturing Inc., Kalida, OH, a divi- sion of KTH Industries, has added a Coe Press tailout (or secondary) feeder to one of its press lines, and as a result is experiencing a reduced scrap rate, and a safer process as well. The feeder, installed to deliver material to a Minster E4H-800 four-point press, resides downstream of a servo-feed unit, and telescopes through the press columns and into the die area. This arrangement reduces scrap, and also results in less material being left in the die—that makes moving remaining material quicker and safer. Coe custom-
designed the tailout feeder—4-in.-dia. upper rolls and 5-in.-dia. lower driven roll—to attach directly to the existing servo-feed unit.
Yaskawa, Motoman
Expanding in Brazil
A new 100,000-sq.-ft. facility near Sao Paulo, Brazil, will soon be the home to Motoman Rototica do Brasil and Yaskawa Electrico do Brasil Ltd., divi- sions of Yaskawa America, Inc., head- quartered in Waukegan, IL. The two divi- sions, which manufacture AC drives, motion-control products and industrial robots, will operate out of 56,000 sq. ft. of manufacturing space and 38,000 sq. ft. of office space; another 6000 sq. ft. will be dedicated to training. Some 150 employees will be located on the new campus.
Four-Axis Fiber-Laser
Welding System Headed
to Italian Manufacturer
Mechanical-seal manufacturer Fluiten Italia S.p.A., Milan, Italy, has commis- sioned a new four-axis fiber-laser-welding system from Prima Power Laserdyne, Champlin, MN. The Laserdyne 430 machine will weld high-pressure and temperature-resistant components used in the manufacture of Fluiten seals. It operates at speeds to 800 in./min., accurate to 0.0005 in., with a work envelope of 23 by 16 by 20 in.
Westward-Ho for
Wisconsin Metalformer
Tenere, Inc., Dresser, WI, a full-serv- ice metalformer offering sheetmetal fab- rication and stamping, plastic injection molding and tool-and-die machining and assembly, has opened a program and sales office in Northern California, to boost its West Coast presence and sup- port customers in the Bay Area. Chad Korbel will manage the office.
Heavy-Gauge CTL Line
to Oregon Metal Slitters
Oregon Metal Slitters, Portland, OR, has installed a new heavy-gauge cut-to- length line from Red Bud Industries, capable of processing material to 1⁄2 in.
First and technology leader in direct drive servo presses
AIDA high torque / low rpm
servo motor
AIDA ECO servo press power management system
Successful track record
Local applications and
training support
Large Size | Transfer & Tandem Lines High Precision Forming | Fine Blanking Mid-Size | Progressive Die & Transfer General Purpose | Gap & Straightside
SERVO & MECHANICAL | 35 - 4,000 TONS
www. .com
MetalForming/December 2012 7
News Fronts
