Page 8 - MetalForming February 2012
P. 8
News Fronts
Facilities
Nikon Metrology Opens New North American Tech Center
Brighton, MI, is the home of a new technology center opened by Nikon Metrology, Inc. On display is the firm’s impressive lineup of prod- ucts including metrology sys- tems, surface profilers, digi- tal microscopes and laser scanners.
Spartanburg Steel Installs Coe Press-Feed Line
Coe Press Equipment, Sterling Heights, MI, has shipped a 30-in. by 10,000- lb. coil-feed line to Spartan- burg Steel Products, Spartan- burg, SC, a manufacturer of metal stampings and welded
subassemblies for the auto- motive, agricultural, lawn-and- garden and heavy-truck industries. The coil line can process steel to 1⁄4 in. thick at 50,000-psi yield strength; its servo roll feed offers a maximum roll speed of 317 ft./min. Included is a power straightener with a 20-hp ac variable-speed drive and digi- tal control, and an alligator- style peeler dekinker station for hands-free threading.
Ace Metal Crafts Moves to New Digs
An 82,000-sq.-ft. plant in Bensenville, IL, is the new home of Ace Metal Crafts, specialists in stainless-steel fabrication. The firm provides laser cutting, forming, weld- ing, sanitary finishes and value engineering. It has stocked the new, larger plant
with plenty of new equip- ment, including a third laser- cutting machine and a nitro- gen-generating system to support its laser-processing operations, as well as addi- tional welding equipment that boosts capacity by
30 percent.
Plater/Metal Finisher Establishes a Presence in Mexico
Incertec, Fridley, MN, a specialty plating and metal- finishing company, has acquired the assets of CRS Aerospace in Empalme, Sonora, Mexico. The facility will provide secondary processes such as NADCAP- certified anodizing, cleaning, painting and nondestructive testing, and within a year also will offer the same processes as the U.S. facility,
including plating on plastics. Incertec will use the facility to serve customers in the aero- space, medical-device, elec- tronics and connector indus- tries operating in Mexico as well as in California.
Waterjet Job Shop Adds Second Two-Axis Cutting Machine
Precision Waterjet Con- cepts, Pequot Lakes, MN, has installed its second two- axis waterjet-cutting machine from Jet Edge Inc., St. Michael, MN. The mid-rail gantry machine features a model iP60-150 waterjet intensifier pump (60 ksi, 150 hp) and can process material to 8 by 13 ft. The company began as a five-axis shop in 2002, and installed its first Jet Edge two-axis machine in 2006.
The most reliable,easy-to-use Heavy-Duty Tool Changer. Ever.
A more reliable fail-safe.
A patented “springless” mechanical fail-safe is guaranteed to work, even with loss of air pressure.
A more reliable locking mechanism.
7,000 pounds of locking force guarantees that signals pass flawlessly, even with heavy accelerations and payloads.
A more flexible utility solution.
Widest choice of modules (power, fluid/air, signal, and more) with common mounting features for greater flexibility.
With patented advances in the locking mechanism and failsafe, and new flexible module mounting and integrated robot mounting patterns, we’ve created the most reliable, easy-to-use Heavy-Duty Tool Changers. Ever.
ATI’s Heavy-Duty Tool Changers have set a new standard.
www.ati-ia.com 919.772.0115
ROBOTIC END EFFECTORS
6 MetalForming/February 2012
