Page 14 - MetalForming February 2012
P. 14
Scrap Choppers are Smooth Operators
Red Bud Industries,
Red Bud, IL, has intro-
duced a scrap chopper
featuring a dual helical
design using a scissor-
type cutting action. This
allows the chopper,
according to company
officials, to operate
more quietly than other
models with a more
controlled and smooth
cutting action. The rotary scrap choppers will only be offered on full Red Bud lines.
The chopper’s knives are attached to a set of rotating drums, driven by an elec- tronic drive. With this design, the rotation of the drums/knives is precisely maintained to create a smooth, scissor-like action to cut the scrap material. This not only reduces sound levels but also minimizes wear and tear on the machine. Each knife features four edges that can be used before the knives must be sharpened. To remove the knives, an operator need only remove one bolt; a locating pin simplifies rein- stalling the knives.
The dual helical scrap choppers are available on Red Bud slitting lines, multiblanking systems and cut-to-length lines with edge-trim systems.
Red Bud Industries: 618/282-3801; www.redbudindustries.com
Eifeler-Lafer Variantic Duplex PVD Treatment
Standard Robotic Solutions for Welding, Press Brake Tending
Wolf Robotics, Fort Collins, CO, intro- duces LeanArc pre-engineered robotic- welding cells in a variety of models and with a selection of options available to suit specific application needs. Included are the robot, positioner, torch, human- machine interface, torch cleaner, operator- safety package and welding power sup- ply, as well as a virtual model of the cell for use in optional offline programming. Also optional are remote diagnostics and programming services.
The firm showcased its Lean-Arc cells at Fabtech
last Novem-
ber, and also
displayed its
new assort-
ment of
robotic press-
brake sys-
tems that
offer metal-
formers a
choice of squaring tables, regrip stations, gripper racks (three-gripper capacity), incoming/outgoing pallet stations and quick-change grippers, while also includ- ing safety equipment and virtual-station offline programming.
Wolf Robotics: 970/225-7600;
www.wolfrobotics.com
CNC Turret Punch
Press Efficiently
Handles Large,
Oversized Workpieces
LVD Strippit, Akron, NY, introduces the Strippit P-1525 20-metric-ton CNC tur- ret punch press, designed to efficiently handle large or oversized workpieces to 60 by 98.4 in. Larger sheets can be processed with clamp repositioning. The press delivers as many as 270 hits/min. on 1-in. centers, and 600 hits/min. in nib- ble mode. The machine provides a
Eifeler-Lafer's in-situ Duplex PVD treatment provides advanced forming support and superior coating adhesion. Variantic-Duplex has replaced CVD and TRD treatments for stamping stainless, DP and AHSS materials.
• D-2 tool steel hardeness checked 47 Rc prior to Variantic Duplex
• Die History: 4 previous TD coatings causing re-coat every 3 months
• All steels were de-coated and treated with Variantic Duplex PVD
• 24 months – 461K quality parts and the die sections look like new
• Low Temperature PVD Variantic Duplex will not distort die sections
Eifeler-Lafer, Inc. – your provider of high-perfomance PVD-coatings
20+ years of thin-film coating experience
Eifeler-Lafer Inc.
3800 Commerce Drive • St. Charles, IL 60174 ph: 630-587-1220 • fax: 630-587-1230 www.eifeler-lafer.com • sales@eifeler-lafer.com
Die sections coated with TRD
Tool damage due to TRD failure
Die sections with TRD coating removed and coated with PVD Variantic Duplex Treatment
12
MetalForming/February 2012
