Page 43 - MetalForming February 2013
P. 43
 cation business,” Torres says. Custom fabrication represents about 20 percent of the firm’s business, the remainder com- prising fabrication and assembly of blowers and enclosures for the food and waste-processing industries, among others.
“Our strategic goal for the last several years,” says Torres, “has been to grow our custom-fabrication business. That’s why we’ve invested in more sophisticated fabrication equip- ment, including the two laser-cutting machines. They elevate our capabilities above many of the shops we’re competing with.”
Targeting Bigger Customers, Bigger Orders
The Republic Sales campus encompasses three build- ings; sheetmetal fabrication lives in a 10,000-sq.-ft. building housing the lasers, four CNC press brakes, and paint and welding departments, and 20 production employees. Any- where from 10 to 20 orders move through the shop per day, comprising part volumes ranging from one to as many as a few thousand.
“We typically process, in custom fabrication, a lot of real- ly small orders,” Torres says. “We’re expecting that our expanded capacity with the new cutting machine will help attract larger orders from big OEM customers.”
The TruLaser 3030 represents what Trumpf called, when introduced a few years ago, a “new design concept—one cut- ting head for all sheet thicknesses.” The machine’s technol- ogy package features lens and nozzle automation, designed to optimize laser-beam-on time and cut edge quality. The technology package’s three key features: automatic nozzle changer, a beam-alignment unit and automatic lens-status inspection. Also helping to justify the new-laser purchase is Republic’s ability to operate the machine unattended, thanks to Trumpf’s LiftMaster automated load/unload system.
An Extra Hour of Cutting per Day
Nozzle size simply becomes one more process parameter in the cutting program downloaded to the machine control as part of a job number. “To cut the full range of material types and thicknesses, we use six different nozzle diameters,” says Torres, “from 0.8 to 2.7 mm. The automated nozzle changer gets the job done in less than a minute, while manual nozzle changes take 5 min. or more. That feature alone provides about an hour of added production time every day.”
In addition to using the right-sized nozzle, laser-cut qual- ity depends on an accurately aligned beam. And during pro- duction, a beam can move out of alignment numerous times per shift, says Torres, especially troubling when customers are specifying dimensional tolerances in the neighborhood of 0.005 in.
“Inspecting and adjusting beam alignment can take 30 to 40 min. when done manually,” Torres says, referring to the firm’s 3-yr.-old cutting machine, which lacks automatic beam alignment. “If we performed that task multiple times per shift we’d never get any work done. So, we specify that our operators inspect and adjust beam alignment twice per
Republic laser-cuts mild- and stainless-steel work from 16 gauge to 3⁄8 in. thick, using six different assist-gas nozzle diame- ters. Thanks to the automated nozzle changer on the firm’s new cutting machine, it gains an extra hour of production time per shift.
shift, or every 4 hr. As a result, we have to deburr some parts coming off of the machine.”
With the new cutting machine and its automated beam- alignment feature, Torres notes a significant improvement in cut quality and a corresponding reduction in cut-edge debur- ring. “We find that the machine’s alignment-inspection process very briefly interrupts production several times per shift, on average,” he says, “as it detects and corrects for minor beam misalignment. Each interruption lasts for just 2 or 3 min., and the resulting improvement in edge quality easily makes up for the lost beam-on time.” MF
A NEW DAY IS DAWNING IN DOUBLE BLANK DETECTION
MetalForming/February 2013 41
Model DS200,
Single Probe Electromagnetic Double Blank Detector With PE Probe
For More Information:
A COMPLETE LINE OF SENSORS AND CONTROLS FOR PRESS PROTECTION Contact or Non-Contact Methods Steel and Non-Ferrous Metals Wide range of thickness levels Engineering Support for unique applications
Call 937.435.8659 or Email vip@primecontrols.com
Visit our online catalog at www.primecontrols.com/catalog
   41   42   43   44   45
