VOC-Free Vanishing Fluid for Forming Zinc
August 3, 2021
Tower Metalworking Fluids
Booth D47127
Tower-VOC-free-metalworking-fluidTower Metalworking Fluids has launched a new product in its Saf-T-Vanish line of VOC stamping and forming fluids.  Saf-T-Vanish 144 is designed to replace solvent-based stamping fluids that are used on galvanized and galvanneal materials.  In most cases, the stamped material is flat-stacked, and VOC-generating fluids have been used to reduce resultant residues that can lead to staining and, in some cases, white rust.  The use of such fluids has been a hazard to the work environment and to workers.  Safe for the environment, Saf-T-Vanish 144 eliminates the propensity for staining even under flat-stacked conditions.
Industry-Related Terms: Forming
See also: Tower Metalworking Fluids
Technologies: Lubrication
