Clamps Rated for Hot-Forming Applications
May 21, 2013Comments
Phd, Inc., Fort ne, IN, a manufacturer of industrial automation equipment, has introduced new high-temperature options for its Series GRM clamps, designed for use in hot-forming applications. The GRM clamps with the G11 option include replacement of urethane-based components with all metal components; high-temperature-resistant seals and lubricant rated to 392 deg. F; and ceramic-coated tips that minimize thermal transfer from the heat source to the clamp.
The new clamps are designed specifically for handling sheetmetal in stamping/fabricating press applications. The clamps are available in three sizes, 13 jaw styles and numerous jaw openings to fit a range of applications.
PHD, Inc.: 800/624-8511; http://www.phdinc.com/grm
Technologies: Bending
There are no comments posted. Bending
Creative Approaches to Common Press Brake Challenges, Part 1...
Tuesday, January 2, 2024
Tuesday, October 31, 2023
