Page 30 - MetalForming-Nov-2018-issue
P. 30
Fabrication: Japan 2018
attention. Throughout the plant, Amada punching, laser-cutting, punch/ laser combo, and press-brake equip- ment shape a sheet-material mix of 70-percent aluminum, 20-percent stainless steel and 10 percent mild steel. Also spied: an Amada FLW4000 4-kW fiber laser-welding machine, and an Amada MARS automatic material-stor- age system, which runs the length of the company’s shop floor.
As we toured, the shop was busy fabricating thin material, 0.02 in. thick, for semiconductor applications, with punch presses with automatic tool changers poised for service. Also, the company’s stable of press brakes formed chassis parts, using new bend- ing tools developed by Kenichiro Maki- no himself. The press-brake operator referred to one as the Miracle Backspin Tool. Another, an offset-bending tool,
was demonstrated on another brake. Makino designed the tools due to pre- cise bending requirements that could not be achieved by what he had seen on the market.
Rapid-Fire Design and Production
Next, it was on to the Fujinomiya Innovation Center (FIC), opened by Amada in 1987. Responsible for con- structing the firm’s forming and fabri- cating equipment, the center occupies 185 acres and employs nearly 1000 peo- ple. Products produced at FIC include turret punch presses, press brakes, bending robots, stamping presses, laser-cutting machines, punch-laser combos and laser-welding machines.
Unique production philosophies and systems enable FIC to deliver dozens of each product type each month—given the surge in manufac- turing worldwide, demand certainly is there. For example, utilizing cross-func- tional teams as well as close collabo- ration with experienced fabricating customers and suppliers, Amada front- loads development work to virtually design products, then quickly develops and tests prototypes.
All necessary equipment, parts and tools are arranged in booth configu- ration so that operators do not have to leave the booth area except for breaks. RFID technology, used for part storage and delivery, tie into a digital manufacturing system to ensure the supply of proper parts as needed, and to ensure proper part inventories. Assembly progress also is tracked dig- itally, from order to shipment.
Automation Drives Productivity at Makino Milling Machine
Also on the tour: A visit to the pro- duction facilities of Makino Milling Machine Co., in Kanagawa. The com- pany, which manufactures machining centers, NC EDMs, milling machines and more, began turning to Amada for fabricating equipment four years ago, to help produce the more than 2000 parts that go into each machine. On the shop floor are Amada fiber-laser
Vibro Transporters
Remove Stamped Components and Scrap Efficiently and Cost Effectively
Model 850
Model 450
Model 320
Model 250
Global Distribution
For over 30 years, the stamping industry has given the stamp of approval to the Vibro Transporter for their scrap removal needs.
At 0.4 cfm, there is no substitute for the efficiency of the Vibro Transporter. Due to their durable rugged design, many of the Vibro Transporters first sold in 1985 are still in operation today.
All four Vibro models are 100% air operated and 100% made in the USA. Each
Vibro unit is backed by a standard two- year, renewable warranty.
Register online or call us to receive your product line kit, application video, engineering support, or to locate a
sales representative nearest you.
MTI MONTERREY, MEXICO
CSP EQUIPMENT INC., Ontario, Canada
VEUGEN INTEGRATED TECHNOLOGIES LTD.
Ontario,Canada
FOSMO & DELI A.S.
Oslo, Norway
717.527.2094
www.vibroindustries.com
28 MetalForming/November 2018
A
E
Y
R
R
Y
T
A
N
W
A
R
