Page 18 - MetalForming-Nov-2018-issue
P. 18
A customized high-speed press provides KSR International with the capability to produce terminal pins to the tune of about 15,000/hr., with annual volumes reaching 14 million. The parts are used in various automotive, light-truck and all- terrain-vehicle applications, as well as in hybrid and electric vehicles.
Then there’s the balancing device, designed to counterbalance the eccen- tric thrust generated from the shaft rotation and slide movement. “Pneu- matically operated, using air pressure and counter weights, we offset the slide velocity,” Wisnoski says. “In so doing, we reduce press-frame vibration and prolong tool life.”
As for addressing KSR’s need to keep the pin-terminal parts oil-free, Wis- noski explains that the guide system incorporates a precision hardened roller system along the length of the guide with the lubrication integrated in the roller housing to ensure proper oil flow. “The rollers are designed to have minimal contact with the guide,” he says, “limiting friction and heat, which allows high speeds to be main- tained during operation.”
The press also has a hydraulic slide- adjustment locking device, standard on all Stamtec high-speed presses. The device hydraulically locks the slide-adjustment threads to eliminate
clearances and ensure consistency of the slide’s position at bottom dead center.
More High-Voltage Parts to Come
KSR remains committed to adding capacity and new business, says Cafarelli. “We are looking at increasing our electronic-parts business, with more high-voltage components, which will expand our microstamping needs and reel-to-reel overmolding. The need for specialty materials such as copper with aluminum inlays will drive new feed equipment, as it has to be scratch- free for wire bonding, and will drive the press area to be more of a clean- room environment.”
“With companies such as KSR con- tinuously showing an ability to inno- vate and a willingness to replace out- dated equipment with new and specialized machine designs,” says Wis- noski, “transportation-parts production will remain on the right track.” MF
Customized Mechanical Press
Press Controls For All Presses
One Source
One Solution
Toledo Integrated Systems
Press Pilot 150 Control
We Provide Solutions For...
Mechanical Presses Hydraulic Presses Forging Presses Transfer Presses
Maximizer TPC (Total Press Control)
Toledo Integrated Systems Toledo Transducers, Inc.
www.ToledoIntegratedSystems.com 800-T-Toledo 419-867-4170
PressBrake
SAFETY
Safety laser beams for optimal press brake safeguarding. Complete systems under $5,000.
Three Position Foot Switch enhance safety for your operators.
Contact us today for more information and visit
www.safeworkplace.org
for additional safeguarding solutions.
Providing safety solutions since 1995
(262) 652-8660 • Kenosha, WI safetysensing@earthlink.net
16 MetalForming/November 2018
7:32 AM
