Page 99 - MetalForming October 2013
P. 99
Automation
NEW APPROACHES NEW SERVICES
Whether it is grinding, polishing, deburring, milling, brushing, measuring, assembling, loading, unloading and palletizing - SHL plants are considered reference systems for complex and technically demanding applications with a focus on surface treatment among the global competition.
Flexible single robot cells, closed grin- ding and polishing cabins, complete production and transfer lines including parts handling: SHL designs, builds and implements the best technical pro- duction solutions.
SHL Automation Inc.
5126 South Royal Atlanta Drive
Tucker, Georgia 30084, USA
Phone: +1 (770) 934 - 0526 Fax: +1 (770) 934 - 3384 info@shl-automation.com www.shl-automation.com
Manual Rollover Positioners for Welding
Bluco Corp. Booth N2411
Bluco will display
its new line of man-
ual rollover posi-
tioners, ready for
use as standalone
weld-fixturing solu-
tions or to comple-
ment an existing
Bluco fixturing
setup. With 360
deg. of rotation, the
positioners provide
welders full access
to all sides of the
part. And, because rotation is clocked in 22.5-deg. increments (custom increments available), the part can always be located at the ideal welding position for each joint.
Double Valve Ideal for Small
Control-Reliable Pneumatic Machines
Ross Controls Booth S4221
Ross Controls, Troy, MI will showcase its DM2 Series D size 2 double valve for con- trol of clutch/brake mechanisms. The 100-percent dynamically monitored valve has complete memory, is control-reliable and Category 4 rated for press applications. Its dirt-tolerant, wear-compensating poppet design provides quick response and high flow capacity. Use it on small gap-frame and die-cut presses, cylinder presses, small shears and on other small control-reliable pneumatic machines.
For Category 4 control-reliable operation of double-acting devices (including shear and cylinder applications), Ross offers its base-mounted Series 77 5/2 Cross- Mirror solenoid pilot-controlled double valves. Available in size 2, 4 and SAE size 4, the valves offer an optional pressure switch for external monitoring, providing for lock- out in the event of a fault, and inhibiting further machine operation until the fault is corrected. www.rosscontrols.com
Visit PMA, MetalForming magazine and Fabricating Product News at Booths N1900 and S4641
www.bluco.com
Surface Heat Treat and Coatings
A One Stop Service Experience Including:
• Pristine quality T.D. coatings with a consistent thickness layer. Surface Heat Treat and Coatings is one of the original T.D. coatings providers in North America
• Arcor/Sursulf Nitriding
• Vacuum Heat Treating
• In-house polishing and inspection
Call us at (905) 664-1966 and visit our website at www.surface-heat.com
MetalForming/October 2013 97
