Page 88 - MetalForming October 2013
P. 88
Previews
Modular, Fine-Spray Lube System
Nordson EFD Booth S4786
Nordson EFD, E. Providence, RI, displays its MC800 system, which applies lubri- cant in a fine, consistently even film. Its easy plug-and-play setup allows for on-the- fly adjustments in a variety of applications. With as many as eight individually con- trolled valves, the MC800 MicroCoat system offers a unique modular setup that allows the user to configure the machine to cater to the specific application needs. Low- maintenance operation and precise lubrication control decrease waste throughout the stamping process.
www.nordsonefd.com
Brawn.
Dallas Press Feeding Equipment lasts and lasts for many years because we design and build everything to handle more than the you buy a Dallas line you buy it fully equipped with heavy gauge materials and without the Dallas machines are built to last, we can easily upgrade them with the latest control
Standard Equipment & Complete Systems
Coil Line Features
Zig-Zag Roll Feed
Coe Press Equipment Booth S4509
Coe Press Equipment, Sterling Heights, MI, will display a conventional coil line featuring its ServoMaster SM2- 18 zig-zag roll feed that allows parts to
Brains.
DallaSmartTM controls minimize electrical and mechanical stress on equipment and material. Whether you are buying new or upgrading existing equipment, they allow you to operate at higher speeds, run larger parts, eliminate surface damage, reduce wear and tear on equipment and material. ProfileSelectTM, our newest offering is ideal for delicate material and progressive die work. The control uses a sinusoidal motion that utilizes 100 percent of the press-feed window.
DallaSmartTM Controls
TM Servo Feed Controls
50,000lb x .135 x 72 wide HSLA
dallasindustries.com 248.583.9400
TM
be fed in a staggered pattern for optimum material usage. Roll speed peaks at 576 ft./min., with a 0.003-in. feed accuracy.
Included in the line is a CPPS-250-18 power straightener with a 60-ft./min. payoff rate, and a CPR-DE-6078 double- ended coil reel. The line can handle coil width to 18 in., and can process 12- in.-wide steel to 0.125 in. thick and 18- in.-wide strip to 0.100 in. Coil weight capability: 6000 lb. www.cpec.com
Custom Vibration-Isolation
Pads
Vibro/Dynamics Booth C1012
Vibro/Dynamics has added a new product to its comprehensive line of vibration-isolation machinery mounting
systems. Custom isolation pads now are available for unique machines that do not have traditional mounting feet that will accept a standard isolator.
www.vibrodynamics.com
30,000lb x 1⁄2 x 20 wide HSLA
86 MetalForming/October 2013
