Page 51 - MetalForming October 2013
P. 51
Servo In-Die Tapping Units
Automated Tapping Systems Booth S4339
ATS, Brick, NJ, will demon- strate its latest in-die tapping units and acces-
sories, including a strip-following tap-
ping unit and two working servo in-die tap- ping units. One servo will demonstrate the firm’s new high-speed air clamp complete tapping station; the other will showcase a five spindle with tap sensors.
www.automatedtappingsystems.com
Modular Welding Table Maximizes Table Area and Load Capacity Strong Hand Tools
Booth N2249
Strong Hand Tools, Pico Rivera, CA, manufacturer of welding clamps, magnets, pliers and welding tables, will introduce its BuildPro Max modular welding table. This newest version of the BuildPro table pro- vides a continuous tabletop surface of pre- cision-ground steel plates (standard Build- Pro tables include 1.7-in. slots between plates for use as clamping edges).
The 8- by 4-ft. BuildPro Max is con- structed of precision, hardened steel plates with 5⁄8-in. machined holes in a 2- by 2-in. grid. Fabricators can insert clamps and modular fixturing compo- nents into the holes for unlimited options when setting up welding fixtures—ded- icated, short run or prototypes. Each plate can be removed and reconfigured to extend the table width, and additional BuildPro plates can be added at either end or the sides.
BuildPro Max table load capacity: 7500 lb. Order the tables with a standard finish, or with a nitrided finish for spat- ter- and wear-resistant corrosion pro-
SEE
US AT
Booth S4306
November 18-21, 2013
tection.
www.stronghandtools.com
...more Fabtech previews continued on page 80
McCormick Place, Chicago IL
Customer Driven, Industry Leading
Die Design and Flattening Software Since 1989
