Page 50 - MetalForming October 2013
P. 50
Previews
Combination Die-Coating Process
Bohler-Uddeholm Corp. Booth S4567
Engineers from Bohler-Uddeholm Corp., Elgin, IL, will be on hand to explain the recent acquisition of Eifeler Coating Technologies, and Eifeler’s Duplex Variantic coating sys- tem. The low-temperature coating process combines plasma nitriding with the Variantic PVD-TiAlCN process. It’s designed to meet the needs of various metalforming process- es, including stamping of advanced high-strength steels (AHSS), and deep drawing.
Visit the booth to learn about the studies that have been done on D2 B-pillar dies, featuring sections coated with Variantic Duplex, used to stamp AHSS.
www.bucorp.com
Feed Control Eschews the Standard Jerky Trapezoidal Profile Dallas Industries
Booth S4415
Dallas Industries, Troy, MI, will demon- strate its unique ProfileSelect feed con- trol and explain how it minimizes electrical and mechanical stress on stamping
equipment and material. Unlike stan- dard controls, ProfileSelect uses a sinu- soidal profile (cam motion), providing a smooth motion and material feed and uti- lizing 100 percent of the press-feed window while putting less stress on all mechanics. Standard press controls use a trapezoidal profile, which results in quick, jerky motions that can slip, put- ting stress on the die and material and potentially damaging the part’s surface.
ProfileSelect is ideally suited for pro- gressive-die work when the part’s cos- metics are a factor or when using delicate material. The controls have an HMI touchscreen and come standard on all new Dallas press-feeding equipment or can be retrofitted to most existing line.
Also on display: a pair of state-of-the- art servo press feeds connected to a net- working, monitoring and analysis system for communicating to the plant floor while monitoring and analyzing equipment efficiencies and providing reports.
www.dallasindustries.com
48
MetalForming/October 2013
