Page 46 - MetalForming October 2013
P. 46
Previews
Feed-Straightener Combo Equipped for Easy Cleaning
CHS Automation/Pneumatic Feed Service Booth S4517
CHS Automation/Pneumatic Feed Service, Roseville, MI, will feature a DRFS-530 servo feed-straightener combination unit with a seven- roll pull-through straightener, powered pinch rolls, powered passline adjustment and piloting straightener design. A high-lift upper bank eases cleaning. The feed- straightener is a part of a com- plete 20,000-lb.-capacity by 30-in.-wide spacesaver coil-feed line and includes a Bosch- Rexroth/Indramat Indramotion
servo control RFX platform.
Also in the booth, Pneumatic Feed Service will showcase a remanufactured servo-roll feed. Only half of the machine will be
reconditioned, to illustrate the firm’s used-equipment reconditioning capabilities.
www.chsautomation.com
Ensure Hydraulic-Press Health and Well Being
Beckwood Press Company Booth S4719
Hydraulic-press manufacturer Beckwood Press Co., St. Louis, MO, will demonstrate its Heartbeat on-board hydraulic-press health-monitoring system. Heartbeat monitors,
in real time, critical press functions. If, for example, fluid-health or pump-effi- ciency levels drift outside of acceptable factory-set parameters, automatic noti- fications can be delivered to predefined departments or employees to facilitate the scheduling of necessary and planned maintenance. This pre-preventive main- tenance tool keeps the operation several steps ahead of unexpected component failure, optimizing hydraulic press effi- ciency. www.beckwoodpress.com
CUSTOM BUILT
CUSTOM BUILT
Unique 4-post compaction press that can form two different products simultane- ously, essentially becoming two presses in a single frame. Using closed-
loop circuitry, the process is totally automated, with each work station receiving programmed commands from a central touch
screen HMI. Sensitive
LDTs and pressure
transducers precisely
measure position and
force. A proportional hydraulic valve controls ram speed and dwell time.
Hydraulic presses engineered for your specific application.
We work with you to design electronically-controlled special- purpose presses that consistently produce high-quality parts and globally competitive productivity.
Call 614-228-0185, ext. 231 for details and an eye-opening quote.
sales@multipress.com www.multipress.com
44 MetalForming/October 2013
