Page 44 - MetalForming October 2013
P. 44
Previews
Software Automatically Logs Downtime
and Reasons in Real Time
Wintriss Controls Group Booth S4737
Wintriss Controls Group will display ShopFloorConnect asset-utilization software, able to collect data from stamping presses, press brakes, laser-cutting machines, tube lasers, tur-
ret presses, machin- ing centers, auto- mated saws, welding machines, injection molders, paint lines and packaging machines. The soft- ware displays real- time machine-status information on a PC or mobile device— no need to install
any special software. It automatically delivers reports showing downtime analysis and OEE, and provides the vital real-time data missing from many ERP and MES systems.
ShopFloorConnect is a turnkey solution that is scalable and flexible, and quickly can be implemented into any discrete man- ufacturing environment. It comes factory-configured to com- municate directly over your LAN with the ShopFloorConnect
Machine Interface (SMI). The SMI installs on any machine, and using only two readily available control signals can track the machine’s operating status, production rate and part count (where applicable)—with no operator involvement. It features built-in Ethernet connectivity to communicate with the ShopFloor- Connect server over an existing network.
Heavy-Duty Performance
Wheel Cuts and Grinds
Metabo Corp. Booth N2444
ity for grinding and metal removal.
www.metabo.us
www.ShopFloorConnect.com
Metabo, West Chester, PA, intro-
duces the Combinator, a combined
cutting and grinding wheel designed
for performance and safety that elim-
inates the need to change abrasive
wheels. Fabricators will use the Com-
binator for cutting, deburring and light grinding. At 5⁄64 in. thick, it cuts quickly. And with three full layers of fiberglass, safety is designed into the wheel for grinding.
Available in 4.5-, 5- and 6-in. Type 27 versions, the wheel employs an improved abrasive/resin formulation for fast cutting with increased wheel life, as well as strength and rigid-
Rock Valley
Oil & Chemical Co.
World Class Stamping Lubricants
Global
• Aerospace
• Electronics
• Consumer Products
• • Structural Components
• HSS/HSLA, Aluminum
• Hydroforming, Deep Draw
ISO 9001:2008
Visit us at Booth S4563
42 MetalForming/October 2013
Rock Valley Oil & Chemical Co. 1911 Windsor Road
www.rock alleyoil.com www.metalformingmagazine.com
