Page 41 - MetalForming October 2013
P. 41
Servo-Press Demonstrations Showcase Stamping,
Deep Drawing and
Blanking Proficiency Aida-America
Booth S4625
Aida-America, Dayton, OH, will display and demonstrate three direct-drive DSF Series servo presses. One of the demon- strations will feature an Aida DSF-N2- 3000, a 300-ton straightside servo press
wheels now utilize a proprietary blend of the firm’s newest-generation SG ceramic- alumina and BlueFireT zirconia-alumina abrasives, combined with a new high per- formance bond system for significantly improved grain microfracturing. The NorZon Plus line also has been expanded with the introduction of NorZon Plus Fast Cut depressed-center wheels, designed for optimum material-removal rates.
The improved microfracturing capability
of NorZon Plus provides a continual supply of serrated cutting edges, enabling unparalleled productivity, wheel life and overall cost effectiveness across a broad spectrum of right-angle grinding appli- cations. NorZon Plus Fast Cut provides a 15- to 30-percent increase in cut rate compared to standard NorZon Plus wheels, say company officials. The wheels are available from 4- to 9-in. dia., 1⁄4 in. thick. www.nortonabrasives.com
Visit us at Booth S4719
recently purchased by Jagemann Stamp- ing, Manitowoc, WI. In cooperation with Formtek/CWP and Pax Products, with material provided by Heidtman Steel Prod- ucts, the press will be producing a pipe flange from 4.5 mm thick, 120 mm wide material via a progressive die operation.
To demonstrate deep drawing in a servo press, Aida will showcase the benefits of using a servo die cushion (from Hyson products) in a servo press. And, at its third demonstration area, booth visitors will spy an HSLA blanking operation, highlighting the ability of a DSF Series servo press to dramatically reduce reverse tonnage. www.aida-america.com
Next-Generation
Right-Angle Grinding Wheels
Norton Abrasives Booth N461
Norton Abrasives, Worcester, MA, unveils a major upgrade to its best-quali- ty depressed-center wheels for right angle grinding applications. Norton NorZon Plus
MetalForming/October 2013 39
