Page 40 - MetalForming October 2013
P. 40
Servo-Driven Mechanical Presses
Komatsu America Industries LLC Booth S4331
Under power at the Komatsu booth in the METALFORM technology area of Fabtech will be a model H1F 200 servo- drive press—a 220-ton single point press featuring a flex- ible automation system and new feed system specifically designed for servo-press applications.
All Komatsu servo presses feature slide accuracy and repeatability measured in microns; fully programmable slide velocity and dwell for optimum throughput and con- trol of reverse loading; and reportedly have at least three times more working energy in the die space than com- parable conventional presses, while consuming 30 per- cent less electrical power. www.komatsupress.com
Showgoers also will want to stop by booth S513,
where Komatsu will display its Twister fine-plasma cutting
machine that cuts 1⁄4-in. mild steel at 180 in./min., 1-in. steel at 45 in./min., and
5⁄8-in. aluminum at 60 in./min. Using the
Quick Sliver
process, Twister cuts 3⁄4-in. stainless steel at 38 in./min. Its patented high-speed swirling assist gas ensures minimal dross
and optimum cut quality.
Auto Feed Magnetic Drill
Fein Power Tool Booth N264
Fein Power
Tool, Inc., Pitts-
burgh, PA, will
debut the Slugger
JCM 200 Auto, a
two-speed fully
automatic
power-feed
magnetic drill
that will cut up
to 2-in.-dia.
holes using
Slugger carbide
annular cutters
in its QuickIn tool-
holder system. At
just 35.7 lb., it
reportedly is the lightest 2-in.-dia.-capac- ity power-feed drill available.
Also new is the Slugger JHM Short- Slugger, a 22-lb. compact workhorse that will drill 13⁄16-in.-dia. And, Fein will introduce a new cordless, handheld, four-speed portable twist drill designed for metalworking applications.
www.feinus.com
38 MetalForming/October 2013
www.komatsuplasma.com
Previews
