Page 38 - MetalForming April 2012
P. 38
Tooling Update
Tooling Technology
CNC Adjustable V-Dies for LVD Strippit Press Brakes
LVD Strippit, Akron, NY, introduces the Vari-Vee V30-140 CNC adjustable V-die, engi- neered for use in its complete range of PPEB and Easy-Form press brakes. The Vari- Vee V30-140 comple- ments the company’s heavy-duty Vari-Vee option. This smaller die offers the benefits of a variable and adjustable-bottom V- die to a broader range of press-brake models— from 320 to 1000 tons,
with length to 315 in. The die provides auto- matic adjustment of the V-width in increments of 0.39 in., minimizing setup time and providing flexi- bility. The variable die allows the bending of sharp angles, to 50 deg. for the maximum V-width, particularly
useful when forming high-strength materials exhibiting significant springback.
The radius on the V-die is a hardened insert machined with LVD’s patented Stone compound curve, for optimal rolling and friction-reducing properties. The die proves ideal for applications that demand bending of different thicknesses of materials; fre-
quent die changes; bending thick mate- rials with large V widths or different radii on the same component; and for bending high-strength materials that tend to crack while bending.
Strippit, Inc.: 800/828-1527;
www.lvdgroup.com
Heavy-Duty Tool- Storage Cabinets
Versatility Professional Tool Storage, LLC, Alsip, IL, introduces a new line of modular storage cabinets designed to support lean and 5S initiatives. Choose from several preconfigured models, or cre- ate your own custom storage unit. Con- figuring a custom unit, the user selects the cabinet shell size, drawer type, base, top and color. Divider systems include user-configurable compartments for hard- ware or components, hard foam for tools
Huge Variety...
Rollblocks For Stamping Presses
• Hydraulic or Mechanical
• Roller or Ball
• Rollers, In-Line or Transverse
• Cartridge Inserts or Rollblock Bar
• Standard or High Temp • Metric and ASA Sizes
SEND FOR A FREE CD OR CATALOG
Visit clrh.com/hilma
Maximize your options, with a variety of die lifters from Hilma for easy, safe movement of dies on stamping presses.
Variations (shown at left) can be found at clrh.com/hilma in Hilma’s online catalog, section K.
Consult with Hilma's engineering staff to determine the best option for your presses and your needs.
16345 Westwoods Business Park Dr. Ellisville, MO 63021
(636) 386-8022 • Fax (636) 386-8034 Tech. Support Call (800) 827-2526 Email: engr@clrh.com
200,000 Lb. Capacity
Proudly Serving the Stamping Industries for Over 50Years
r Driv
k
Red Stag Engineering & Automation, Inc.
N2548 Meadow View Cour Waupaca, WI 54981 Phone: 715 258-507 Fax: 715 258-5242 Email: Redstag@waupacaonline.net
Red Stag builds custom hydraulic presses from 500 ton to 18,000 tons
www.redstag.com
36 MetalForming/April 2012
