Page 22 - MetalForming February 2012
P. 22
CNC Machine
Slip-on Abrasives Save Time & Money
Shadow-free
matte finish –
up to a mirror polish
BE 5
Double-sided Deburring of Sheet Metal up to .2" Thick
• Simple, one-step deburring
• 40, 60, 80 and 100 grit flap wheels
• 2 speeds: 600/1200 RPM
PIPE-MAX Pipe Belt Sander
• Polish stainless and all metals
• For sanding handrails and pipes up to 12”
• Grinds weld seams on flat surfaces
Visit csunitec.com
for our full line of industrial power tools, and to view demo videos.
Surface Finishing Solutions
Tooling the Parts
The traditional method for adding tooling to parts—to tool each part and save it to a library, and then recall these parts as required for nesting—presents a few disadvantages. Should a revision be created, the fabricator will have to retool. Or, the tool assigned to the part may no longer be available. Also, if multiple parts are nested with con- flicting tool stations, changes must be made that will delay moving the nest to the shop floor.
An ideal nesting system offers both —the traditional method and an option to tool parts quickly as they are nested. This system uses the available tools, minimizes tool setup and changes, and quickly makes nests available to the shop floor. All of this keeps those expensive punching machines run- ning, and maximizes profitability.
Completing the Process
Toward the end of the nesting process, the programmer sends the part nest to the shop floor. What hap- pens if the all of the parts are not included in the nest, which can be caused by a variety of issues including incorrect tool changes or a power out- age? In this case, the operator must make a notation on the paperwork and request an immediate, updated nest from the programmer.
With a more integrated software sys- tem, communication between pro- grammer and machine operator becomes more effective and produc- tive. An operator can reject a part using the software installed at the machine.
Businesses also can apply rules that require the operator to state a reason for a rejection, to allow proper tracking of downtime and engineering changes. Once rejected, the information is auto- matically sent back to the nesting sys- tem as a high-priority part. Then a new nest can be developed and the part can be combined on a nest that con- tains any newer parts that require the same material type and thickness.
The end result: Less hassle, better material utilization, and a more accu- rate tracking of stock. MF
Press Controls For All Presses
One Source
One Solution
Toledo Integrated Systems
Press Pilot 150 Control
We Provide Solutions For...
Mechanical Presses Hydraulic Presses Forging Presses Transfer Presses
Maximizer TPC (Total Press Control)
Toledo Integrated Systems Toledo Transducers, Inc.
www.ToledoIntegratedSystems.com 800-T-Toledo 419-867-4170
20 MetalForming/February 2012
