Page 9 - MetalForming December 2010
P. 9
generated purely from the waste heat of its industrial welding processes. Previ- ously, in its older plant, the company used supplemental heaters, kept the ship- ping doors open more frequently, and used exhaust fans to expel welding fumes—and wintertime heat. Now the company incurs no supplemental winter heating costs, significantly reduces heat
loss during open-door periods, and recir- culates heated air through the air curtains. The air curtains activate manually or with a limit switch triggered by a door opening. They draw interior air from the facility and discharge it through
field-adjustable nozzles.
Berner Intl.: 724/658-3551;
www.berner.com
connect everywhere
Network your factories and offices with SmartPAC 2 and LETS (Line Efficiency Tracking Software)
Take advantage of
SmartPAC 2’s built-in Ethernet connectivity to communicate over your network.
Send and receive text messages, display setup sheets stored on a central server, back up your tools to a remote location, and view pressroom status over the network and internet. When you connect your equipment to LETS, you can collect production data, feed critical parameters reports automatically, view machine status in real time, and schedule a prioritized job queue for each machine.
To learn more about Wintriss Controls, please call 1-800-586-8324 or visit www.wintriss.com. ®2010 Wintriss Controls. All rights reserved.
tenance requirements and increased energy efficiency. The power supply also is much smaller than that for CO2, and fiber delivery enables the beam to trav- el greater distances, allowing for instal- lation on larger tables.
Hypertherm: 603/643-3441;
www.hypertherm.com
Air Curtains Slash
Energy Costs, Filter
Welding Fumes
Coleman Tool & Mfg. Co., Union Grove, WI, a metal fabricator of replacement parts for garbage trucks, roll-off trucks, refuse equipment and similar applica- tions, originally specified air curtains above its open doorways to reduce its monthly winter heating costs. It soon dis- covered an added benefit of the air cur- tains (from Berner Intl., New Castle, PA): filtering welding fumes, to significantly improve employee indoor air quality (IAQ).
For its new 60,000-sq.-ft. plant, Coleman specified air curtains, above two 16 by 16-ft. and one 12 by 12-ft. overhead doors. The curtains retain heat while the doors are open, allowing the irm to maintain a 60 F wintertime temperature
METALFORMING / DECEMBER 2010 7
