Page 53 - MetalForming October 2010
P. 53
Operating
Old Metalforming
Equipment?
Picture a Whole New Level of Performance with Pacific’s Productivity Enhancement Program (PEP).
In fact, PEP is the cost-effective and proven way to boost productivity, but without the expense of new machines. Whether you have an outmoded hydraulic press, press brake or plate shear, we can upgrade features so it meets new production and safety standards and is “back-to-productive-life”.
Upgrade Equipment in Half the Time - at a fraction of the Cost!
When your metalforming equipment is older or non-productive, PEP is your best option for increasing its speed, accuracy and productivity.
downtime.
manufacturer’s hydraulic press, press brake or
plate shear equipment.
See for yourself how our PEP program can bring better productivity for years to come!
Contact us to learn more:
www.pacific-press.com
servo transfers, robust and flexible, have an unrestricted range of motion, opening up the press for new programs. Motion profiles are smoother than the restricted mechanical pro- files, and with the elimination of mechanical slop and round- ed-out curves, transfer-rail deflection is minimal, allowing very heavy payloads to run at much higher speeds then ever thought possible in the past.
www.lineartransfer.com
Precision-Slit Stainless-Steel Coil
Stainless Sales Corp. Booth 1649
Stainless Sales Corp., Chicago, IL, is an ISO/TS-certified, woman-owned business that provides stainless-steel slit coil from 0.015 to 0.250 in. thick, for traditional and surface-critical appli- cations. Visit the booth to learn more about its inventory-man- agement and other support services that enable the company to meet demanding deadlines and maintain efficient operations. www.stainlesssales.com
Software Sets the Stage for Successful
Die Design
3-D Solutions Design Service Booth 1036
3-D Solutions, Rock-
ford, MI, will provide
live demonstrations of
the Power Catalog, Power Tem-
plates and Power Apps software, engi-
neered for designers completing complex progressive dies or large transfer die designs, even those done with cast-style die shoes or cast internal components. The firm also will demon- strate its transfer-simulation quick-turnaround service—using your press curves, part data and die design to check for inter- ferences through a transfer die, 3-D Solutions will provide a cor- rective-action report, simulation movies (with collisions iden- tified) and optimized press curves.
www.3ddiedesign.com
Production Line for
Stamping Small Parts
Stamtec, Inc. Booth 1633
Stamtec, Manchester, TN, will display a full, functioning pro- duction line for stamping out small parts. The line will include a model OCP-35 single-point gap- frame press equipped with a Stamtec feedline, quick-die- change system and stamping die. www.stamtec.com
METALFORMING / OCTOBER 2010 51
